Software, Firmware and Drivers
> w660i SEUS
On 2008-09-28 21:52:36, groovepeppy wrote:
just transfer it to your phone, it should play it well without any problem as long as it's flashlite 1.0......
i cant play them. i converted them using
http://www.erightsoft.com/SUPER.html#Dnload
Posted: 2008-09-29 01:39:18
well, i never convert anything to flashlite so i'm not sure what's went wrong but my phone do show flashlite 1.0 nicely as a wallpaper or menu...
Posted: 2008-10-01 14:05:41
If the files are with higher unsupported resolution the phone won't play them probably... But never heard before for converting flash files...
At least I'm not very familiar with it.
Posted: 2008-10-01 19:24:04
i can used those .swf files from flash theme as Wallpaper and Screensaver.
but those i converted, i cant used them for both WP and SS.
1. what must be the size or resolution of the converted .swf files?
2. i have macromedia flash 8 editor. can i save them to flash 1.0 for my w660i ?
Posted: 2008-10-02 13:21:02
On 2008-09-28 09:48:00, strizlow800 wrote:
SEUS also converts the phone to CID53 so if you plan on modding your phone, or if it is still CID52 don't use SEUS to update the firmware. you have an alternative like XS++ for e.g.
hi there mate.
what can i do with my w660i except SEUS update? flashing, upgrading, modding, etc?
heres my phone info:
22:11:48| XS++ v3.1 (Darwin) Ready !
22:11:48| Executed on Microsoft Windows XP
22:12:08|
22:12:08| Attempting to open the interface...
22:12:08|
22:12:08| TURN OFF PHONE!
22:12:08| Hold 'C' button on phone and connect phone NOW.
22:12:08| You have 30 seconds...
22:12:08|
22:12:14| Baseband ID: 9900
22:12:14| Protocol Version: 3.1
22:12:15| Phone name detected!
22:12:15|
22:12:15| Profiling SEMC phone...
22:12:15| Platform: DB2020
22:12:15| OTP CID: 51
22:12:15| EROM CID: 52
22:12:15| EROM Color: Red
22:12:15| IMEI: 35958401xxxxxx
22:12:15| Phone ID: W660
22:12:15| Region: APAC
22:12:15| CDA: CDA102568/101 R8A
22:12:15| Firmware Version: R8BB001
22:12:15| EROM: R3A022
22:12:15| Ready for operation!
22:13:09|
22:13:09| Sending db2020_cid01_prodid_p3j.bin...
22:13:09| Applet ID: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J
22:13:09| This is a PRODUCTION_ID loader
22:13:09|
22:13:09| Sending db2020_mem_patcher_cid52_r2a006.bin...
22:13:10| Applet ID: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
22:13:10| This is a MEM_PATCHER loader
22:13:10|
22:13:10| Sending db2020_red52_cs_r3a009.bin...
22:13:12| Applet ID: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009
22:13:12| This is a CHIPSELECT loader
22:13:12| Activating loader...
22:13:12| Activating GDFS...
22:13:27| This loader is UNLOCKED
22:13:27| Backing up the GDFS...
22:13:29| Stated variables: 1458
22:13:32| Variables found: 665
22:13:35| Variables found: 662
22:13:36| Variables found: 131
22:13:36| Wrote backup to .\\Backup\\W660_xxxxxxxxxxxxxx_GDFS_BACKUP.bin
22:13:36| GDFS was backed up successfully!
22:13:36| GDFS operation was successful
22:13:38| Disconnected... Unplug the phone
Posted: 2008-10-03 16:32:47
It is CID52 which means you can do everything you want with it. You can apply every mod possible for it as there are no modding limitations. Make backup of the GDFS, store it safely and go in a hunt for mods.
Posted: 2008-10-03 18:42:35
thanks a lot, mate..
Posted: 2008-10-08 06:35:36
Latest fw for W660i
R6BC002
Posted: 2008-10-10 18:13:01
On 2008-10-10 18:13:01, groovepeppy wrote:
Latest fw for W660i
R6BC002
where can i download it? can u post the link?
Posted: 2008-10-13 15:03:15
Here
it's europe....
Posted: 2008-10-13 16:12:18
