Sony Ericsson / Sony : Software, Firmware and Drivers : K750i SEUS R1N035 update problems/potential solutions
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > K750i SEUS R1N035 update problems/potential solutions Bookmark topic
Page <  123 ... 373839 ... 535455>
ac328 Posts: 24
I can't seem to update at SEUS, instead I am getting commincation errors again.
Posted: 2005-10-06 18:42:32
blumx Posts: 73
Suggestion for communication error problem:
Change the regional settings to English from Control Panel and try again. This solved the problem in Turkey (at least)
Posted: 2005-10-07 13:43:20
Astxxx Posts: 7
Yes. It is right. It fixed the problem.
Posted: 2005-10-07 13:55:44
dgilmartin Posts: > 500
When I tried to update today on both the UK and Asian SEUS site, it says,
then,
The thing is my phone is unbranded and unlocked. It came that way direct from CPW. Does anyone have any ideas?
Cheers
Dan
Posted: 2005-10-07 17:16:45
ac328 Posts: 24
i had the same problem, try going to the Asia pacific site, like Hong Kong English.
Anyone help with communication error?
Posted: 2005-10-07 22:44:12
ac328 Posts: 24
for those of you who successfully updated. did u leave the sim and memorystick inside the phone?
Posted: 2005-10-07 22:47:28
pappfer Posts: 109
Yes i did and everything works fine.
Posted: 2005-10-07 23:53:44
GeKoX Posts: 24
Did anyone else having problem with freeze at 50% and communication error problem tried this tip ?
Posted: 2005-10-07 23:58:25
samreen Posts: 59
yes the joystick has 8 directions in R1N firmware. It's usually giving problem in downward direction when held in left hand specially.
Posted: 2005-10-08 00:26:12
GeKoX Posts: 24
Finally i've done it, i have the R1N035.
To update, like somepeople says it before and may be it helps.(Thanks them for those tips)
- Turn the phone to english language
- Do a reset, don't need to do the big one, just the little reset
- Don't update with the MScard in the phone.
I've done like this, it worked, i don't know if it helped, or may be the file have an update, see this.
The update slow down at 43% then seems to stop at 53% and finally take a big speed to 100%
HL1_125952-EU1-MR2_000000_0000_R1N035
HL1_125953-FR1-MR2-B_000000_0000_R1N035
There's a letter B in the name of the second file, B for bugfix ?
I don't know if this file had the same name before my last update that have sucked at 50%.
So, am i happy ?
Don't know yet, i'm gonna see tomorrow.
Posted: 2005-10-08 02:43:01
