Sony Ericsson / Sony : Software, Firmware and Drivers : New Modded Camera Driver for K550i
Friends, you can take parts from my driver, I shall not be against. I forbid nobody. I am not assured of stability, but, I think anything terrible will not occur.
Chris067, many thanks! I trust you.)))
Raiderski, I not against if you will look my driver and something will take therefrom.
Salamabada, probably, I have a little corrected color temperature here.
number1, no comments.
P.S. 2ALL If you think that I am afraid, that my driver will disassemble on pieces you are mistaken.
P.P.S. Chris067,
respect, u on a true way, my friend.
P.P.P.S. Somebody at this forum can trust me?
[ This Message was edited by: SonarikK510 on 2007-10-16 14:08 ]
Posted: 2007-10-16 14:56:21
I have installed SONARIK' 2.34alpha version of camconfig (let me call it as config, not driver. real driver is some other thing.). alpha is very goog version. video sport mode is very well. I like it to shot home video!
thanks to SONARIK.
Posted: 2007-10-16 15:31:07
Guys, now I spent the test. The test of values ISO.
Here, that I managed to find out:
Electronic strengthening is applied poorly. Did two photos - one with ISO160 and another with ISO500. Distinctions between 160 and 500 practically are not present, but on 500 the picture (the effect of reduction of noise is applied) strongly spoils. The similar effect is applied to all photos, at which value ISO above than 250. I have decided to clean all those values, which above 250 (320, 400, 500, 640, 800). Simply enough to equate them to 250. You agree with it? I think without this "effect" of a photo will look where more pleasantly.
So, you agree with it?
Posted: 2007-10-16 17:53:46
SonarikK510
Just release new version of driver and community will anwser.
We should run some tests on it. ^_^
@Chris067
I ve tested your driver, but when u applied new setting for Video capturing it appears also in Photo mode. Thats bad. Thats why Sonarik's mode is very usefull.
[ This Message was edited by: Leshcat on 2007-10-16 17:22 ]
Posted: 2007-10-16 18:19:07
chris067, At present I know a way how to set the fixed values of shutter speed and ISO. I am able to do it, having replaced four effects.
Posted: 2007-10-16 19:00:46
Shit, that way which I thought that will turn out, does not work. I think to disable effect of reduction of noise it is possible if to set only in an automatic mode value ISO250. That's my idea at present time. Maybe who has another ideas?
Posted: 2007-10-16 20:11:56
Leshcat,
"when u applied new setting for Video capturing it appears also in Photo mode"
--> now it works that way : 24fps stable mode is still enabled by default.
if you want to get unmodified setting (with more light when pointing
in a dark area, as it is required for taking pictures), just switch to picture mode (small icon),SHUT LENS COVER and OPEN IT AGAIN. Back to original !
If you want to go to 24 fps stable mode, just switch to video mode (small icon), WITHOUT shutting lens cover.
Very simple and intuitive, isnt it ?
I have slightly improved 24fps stable in night mode : just a little bit
more light, and just a little bit less fps
Sonarick,
What about using zoom button +/- for manual choice of shutter speed (or ISO) ? I think you can do it, am I right ? Thanks !
Number 1,
Normal zoom (the one actually we have on K550) :
when you want to zoom, we press a +/- button, and the camera zooms
only 1 step. it we kkep the finger on, say, the + button, the camera
zooms with visible "steps" (means, say, 1.2xZoom, 1/2 sec wait, 1.3xZoom,
1/2 sec wait, 1.4xZoom, ... until the final 4xZoom.
Linear zoom (the one we dont have):
When you keep the finger on the + zoom button, the camera should
zoom WITHOUT pausing each step, from 1x to 4x.
[ This Message was edited by: chris067 on 2007-10-17 02:54 ]
Posted: 2007-10-17 03:51:00
Chris067, maybe, maybe. I'm not sure on this.
Posted: 2007-10-17 15:25:43
Thanks for the new driver chris.
Can you integrate it with your old 24fps + em driver?
Essentially, can you make a driver with the following features:
1) Night portrait is em mode.
2) Video mode alone is stable fps.
3) The phone reverts back to standard video if night mode is enabled in video.
4) The stable fps mode doesn't affect the still camera. i.e. its possible to go to video mode and come back without affecting the still camera's performance.
5) The saturation should be increased slightly.
I think that this would make a very nice driver.
Posted: 2007-10-17 18:25:17
Yes, it should be possible !
I'm actually a bit busy ( I just got a new job ), but I will see
that following days.
cheers
Posted: 2007-10-17 22:45:34
