Regional : Asia Pacific : Free Globe Mobile Internet Browsing Using Opera Mini 2.00
Esato Forum Index > Regional > Asia Pacific > Free Globe Mobile Internet Browsing Using Opera Mini 2.00 Bookmark topic
Page <  123 ... 373839 ... 535455>
dennevhyn_31 Posts: > 500
Ok, next time make sure na wag kang magduduplicate sa post mo kasi baka maclose or malock itong topic natin. Anyway, basta put 3g.myglobe.com.ph@ lang po sa download link. It should work talaga. If you have other questions, just let me know. You can PM or you can add me nalang sa YM po. By the way, try mo rin gamitin ung Opera Mini 4.2. Free lahat dun using myGlobe INET internet profile.
Posted: 2008-12-04 14:13:28
On 2008-12-02 22:44:36, Zoity wrote:
Help po PLEASE...
Na Download ko na po ung Mod. na Opera Mini Nyu kaso ayaw padin Gumana...
Motorola E680i ung Model ng CP ko, eto lng ung naka lagay sa "DATA NETWORK" ko...
Profile name:
____________________________________
GPRS setting:
APN:________________________________
Username:___________________________
Password:___________________________
Timeout:(may pagpipilian) "OFF - 15min - 1hr - 2hr - 6hr - 12hr - 24hr"
[ ] DNS server
(1) ___.___.___.___.
(2) ___.___.___.___.
CSD setting:
Dial in number:_______________________
[ ] Query at Login:
Baud rate:(may pagpipilian) "Auto - 14400 - 9600 - 4800 - 2400"
Line type: (may pagpipilian) "Modem - ISDN"
Timeout: (may pagpipilian) "1min - 5min - 15min - 30min - 60min"
[ ] DNS server
Eto ung Mismong naka lagay sa CP ko ^_^
Pa Guide naman po kung anu ung mga gaagwin ko d2
Salamat in ADVANCE ^_^
Mas maganda if iddownload mo nalang ung internet settings para hindi ka mahirapan sa pagcoconfigure nyan manually. You can call Smart customer service or just text SET 3G to 211.
Posted: 2008-12-04 14:18:58
Zoity Posts: 0
Hmmm nka connect ne me.. kaso ung sa Browser nlgn ung nagFfaild...
Eto ung may mga Red na sulat...
ung sa The Address To Connect...
"Connection does not exist"
"To connect using ports 80.443 and 8080 the application must be entrusted"
Globe User po ako ok.. ^_^
Salamat in advance ulit.. ^_^
Posted: 2008-12-04 19:14:31
What do you mean nakaconnect ka na? Nakapagbrowse ka na ba? Check mo muna ung settings. Ung red na nakita mo eh un ung nasa network settings. Basta ung address to connect ay www.globe.com.ph/globe.asp. myGlobe CONNECT ang gamitin mong internet profile at setting for java.
Posted: 2008-12-04 19:35:42
Zoity Posts: 0
Ah.. nakaka connect na po ung myGlobe CONNECT ko...
Pero ayaw padin po mag Browse... tama naman po ung sa address to connect ko pero ayaw padin gumana...
Hmmm 2.06 nga po pla ung gamit ko...
Posted: 2008-12-04 22:21:34
ganon? try ko ulet sa phone ko ung opera mini 2.06 using globe. check ko kung working pa talaga cya now. if you want, install opera mini 4.2 then use myglobe INET as the internet profile. free browsing na un.
Posted: 2008-12-05 00:03:10
Zoity Posts: 0
ang lumabas naman ngaun ''an error occurred b;java.io. EOFExeption"
nung nagtesting ako sa mini opera sabi you a working network connectio,, tapos nung nagbrowse ako ito lumbas''an error occurred b;java.io. EOFExeption"
help naman..salamat..
Posted: 2008-12-05 08:50:02
Zoity Posts: 0
ang gamit ko kasi mod v2.06, and nagkaroon na ako ng working connection. kailangan ko pa ba ilagay sa setting ung mga steps na nkapost sa unang una?
Posted: 2008-12-05 09:07:55
bluefoxx Posts: 0
@den ok nmn ung settings ng real player ko...by the way im using e90...unable to connect talaga!
Posted: 2008-12-05 09:57:13
Zoity Posts: 0
ngaun naman my lumabas na important note and terms and condition about sa opera mini? para saaan yon?
Posted: 2008-12-05 10:00:06
