Other manufacturers
> The Official Esato iPhone Club!
yes, ziphone has links to each firmware in its "help and info" so you can download it to your pc
here is 1.1.4
in itunes just hold the shift key while you press restore and you get a dialogue to select the file to restore
Posted: 2008-04-23 22:27:58
Hi mate,
Thanks for the help I've promised to help someone get his iPhone unlocked and updated etc. What program do you need to update the edge settings as he is on voda?
Posted: 2008-04-23 22:39:02
you don't need any program. on the phone, just go to settings > general > network and click EDGE and enter "internet" (no quotes) as the APN
Posted: 2008-04-23 22:45:33
Apple Considering 'Free' Access to iTunes Library
http://www.mobile-tech-today.[....]_Library&story_id=112004ONZA3K
Posted: 2008-04-23 23:20:12
Hi all,
Well i have officially joined the Club now got mine this afternoon but didn't do anything till about 22:00. All went fine and was easy with ZiPhone accept i still had 1.13 firmware and no installer or Z Blog icons.
So went to iTunes to upgrade and restore and then disaster struck at the end of the upgrade it said error and i was stuck in restore mode neither itunes or Ziphone and using downloaded 1.14 firmware would finish.
About one hour later and about 12 attempts it eventually did restore and upgrade and then just used ZiPhone again to unlock jailbrake and activate.
So as long as you don't a PANIC and keep on trying it does all work out in the end.
It is taking me a little while to get to grips with it all and the very different system, just want to ensure i don't end up with a huge Data bill when out of WiFi cover but i suppose as long as i don't have anything auto updating it should be fine. Or is some going to tell me that's wrong?
What i really can't believe is how smooth and fast it is and once i stop looking for a stylus it will be great. Think i still need to spend a few hours downloading the apps i want and setting it all up have already started shifting the icons i won't be using onto a second page.
Will let you all know in a couple of a days how i have 3G/HSDPA with mine well sort of i could get the speeds.
Marc
iPhone 8GB 1.14
Nokia E90,8GB SDHC, Fring, Seven, Tom Tom 6
Dogmanns Nokia E90 Blog @
http://dogmann.vox.com/
Honoured to have won BEST DEBATER
[ This Message was edited by: Dogmann on 2008-04-24 12:17 ]
Posted: 2008-04-24 04:26:21
i havent found nethin that auto updates as long as the mail is set to check manually....
And u can always check data transfer amounts under settings and useage which is always handy like.
And i had a worry last night i installed the 'game' ants and it totally fooked ma iphone making me have to restore it and ziphone it again lol.
Enjoy the iphone dogmann!
Posted: 2008-04-24 09:46:13
I ran ziphone last night after i restored and upgraded from 1.0.1 (the original firmware?) and it was running for about 15 mins and the white text had stopped scrolling on my iphone so had to stop it and restore again through itunes, but it worked all fine the second time round
My iphone is really fast now and am glad i updated to 1.1.4.
Posted: 2008-04-24 11:58:45
i have a dent on my iPhone i was wondering how can i remove this? how can it be fixed?
[ This Message was edited by: sepehr_sz on 2008-04-24 15:51 ]
Posted: 2008-04-24 16:51:02
this video will probably give you some idea of what is involved
http://youtube.com/watch?v=X1z0pw2VK7M
Posted: 2008-04-24 17:02:54
font size=-1>[ This Message was edited by: Dogmann on 2008-04-24 12:17 ]
Marc if you are concerned just turn the data off at first to get the hang of things.. use bossprefs as you mentioned before to turn off edge... you'll know it's off cause it'll either prompt with a wifi network that's closeby or tell you "there is no edge connection available"
Posted: 2008-04-24 20:56:39
